Project Silvia *updated*
LeeS13
Post by LeeS13 »
loving the Hoover hose lads :-D
if you want some standard intercooler pipework i have a bag full of bits you could have a look through
323ian
Post by 323ian »
Lee that would be really usefull if i could have a look through it mate?
Can give you your steering boss back as well!
LeeS13
Post by LeeS13 »
not a problem will have a look on sunday night and let you know
may i advize that you go to B&Q to get some under ground wire covering tubes
as they are well reinforsed. but its a dam good idea thow :lol:
323ian
Post by 323ian »
Can you use that stuff for intercooler hose then bart?
This is a car being built on the cheap and silicone hoses and bends are not cheap!
Ian, I have learn't that when Bart has what most people would class as a crazy idea they often work.
You've seen and heard his Sierra Gt that he uses for drifting.....He built the induction kit for it...The same principal as a K&N 57i genII kit. Except it didn't cost him
Just spoke to Al (Bart) and he said that there some of that tubing in my shed so i've taken a picture of it for you. This tube is bendable and you can stand on it.
323ian
Post by 323ian »
Thanks for that Paul, much apprecited.
I put an induction kit on this Silvia for about 20pence! Was an old cone filter and filed it to shape so it would wedge into the AFM!
That pipe would be ok but i am not sure the airflow would be to good with all those ridges, not sure also how you could join it at the end as you could not use a jubilee clamp.
Thanks though mate.
that tube is ridged on the out side but the the inside of it is smooth but with little shallow rids that will not make that
much difference. i have used this stuff for air flow for brakes and a direct feed for my induction kit
as pablo has already stated. you can use a jubilee clamp but may have to cut slight bit from the inside
to fit but will still be stiff.
the pipe i use has sustained speeds of 130mph with a 90 degree bend in it.
323ian
Post by 323ian »
Sounds like the stuff for me then, cheap and functional!! :-D
