I take it your test uppipe is a 2.5" ID 3-bolt pipe. I haven't seen any at 2.5" 3-bolt, they all seem to be 3". I may be interested in that if you get some good results and it shows quicker and much lower RPM spoolup.Area 52 Autosport wrote:You are entirely correct, the standard 3 bolt up pipe is way to big for any stock turbine housing. We have a test up pipe here which is set to replace it in our 3 bolt manifold kits. .ScoobieWRX wrote:What i have sussed out from all this, and having done some more logging today, is that i'm not sure now if the decat 3 bolt uppipe that's part of the GT Spec GenII headers is a bit much for the VF35, and i'm now thinking a smaller diameter pipe would be better suited to the VF35 producing better spool up lower down.
Jase.
With my setup that is the STi8 with STi TMIC, VF35, STi pinks, flat panel air filter, snorkus mod, catted 3" downpipe, walbro pump and adjustable fuel pressure reg + the headers and uppipe, what do you reckon is the best i could reliably hope for?
At the moment I get 1.48bar peak boost down to 1.12bar at the redline. I run mid 11 AFR's on Tesco 99RON, no additives, no IC spray.
Your pro advice would be gratefully accepted.
