Sevenoaks North Weald 31st August
im quite happy 'cocking around cones' :D well it gives me a buzz anyway
blacky
Post by blacky »
Yup, the only one I don't like that much is North weald. Bentwaters is fun as its so fast, Debden, hmmm, not sure but its okay.
Yup, I'll echo the thoughts on Bill, seems silly he can't run in another class, and the inconsitency of the officals isn't impressive.
blacky
Post by blacky »
IWANT1 wrote:Got to get myself to one of these sometime soon maybe just as a spectator to start with to see what the crack is..
Whats up with the clutch my twin plate loves a launch?
Good result baz?
Mate, your AX would go well....just get it out to play!
Just me probably, how do you launch yours?? I've had advice not to side step it as it'll blow the transfer box.
IWANT1
Post by IWANT1 »
What am I likely to be up against due to its spec (what clas)?
The norm usually logan, 4 1/2k-6k depending how my mechanical sympathy is on the day pulling up the revs accordingly. I used to side step the old paddle but now just rapidly release the twin plate as it doesn
blacky
Post by blacky »
Lee
Is your fully stripped etc?? if so you'll be in class D6 which is up to 1400cc and you'll be able to run slicks and be up against other AX's, usually there are a few tweeked mini's running 1380cc on big carbs etc, reckon yours would be okay if your a half decent pilot.
Yes, I was trying to feed it in but as I'm not used to doing that it was a bit hit or miss, I think I managed 1 decent one out of 5.....shocking, will have to practice some more!
I'm not on sticky rubber, just Bridgestone RE070's
IWANT1
Post by IWANT1 »
Completely stripped as in no clocks, door cards etc think iam going to need to get hold of a little blue book to see if any mods will need doing.
blacky
Post by blacky »
Have a read of the championship regs and entry on http://www.aemc.org.uk for an idea of which class you'd be in.
