The last few months have seen me:
- Fully strip and re-furb/re-paint the rear TT subframe
- Rebuild and re-furb the TT diff
- Fitted DW solid rear subframe bushes
- Fitted DW solid diff bushes (rear)
- Fitted Japspeed polybush diff bushes (front)
- Re-fitted the TEIN Type Flex coilovers front and rear (lowered by a further 60mm all round)
- Re-furbed and re-fitted all of the DW rear adjustable arms and DW HICAS kit
- Removed the Origin Lab carbon GT wing due to a 'mis-hap' (read: the entire car fell off the stands, crashed into a caravan and fooked' the wing)
- Fitted and painted the custom rear wide arch kit (now approximately 100mm wider than stock)
- Fitted Mitsubishi Evo PAS cooler
- Fitted Super Pro steering rack polybushes
- Heat sleeved the PAS cooler pipework
- Stripped and repainted the main dashboard bar
- The VG31DETT has been fully stripped and intricately re-built, replaced all gaskets and re-furbed all ancillary components
- Ported and polished lower plenum
- Re-built and ported/polished both heads, seated new valves
- Re-built both GT675 RS turbos (ball ache of a job)
- Replaced stock CAS disc with upgraded AEM CAS disc (another ball ache of a job)
- Rubbed down and painted underneath entire car
*Engine going back together right now....boom!
