supercharger
Bladerider
Post by Bladerider »
I understand what you are saying,
But the turbo doesnt spool because it gets hot, it spools because gas flows through it !!! The more heat you can keep in the better as this helps the gas to flow faster - hence why wrapping is such a good idea, but I certainly wouldnt advise people on trying to get the maximum EGT's they could without qualifying the argument.
Ask Mr Norris about what happens when people who dont know what EGT's can do play with your car !!!
J.
alexb
Post by alexb »
I'm not saying a hot turbine spins quicker, just that there's more energy in the gases spinning the turbine. I also know that there are limits to an engine's and a turbo's life with excessive EGT.
Scott, help me out with an example of your own?! I bet you've played with EGT while keeping the other characteristics the same and measured the difference?
Cheers,
Alex
hybrid dreams
Post by hybrid dreams »
and hotter gases have more expansion. which means more "volume" or "energy" as some put it. EGTs dont spool turbos directly. its how it was said. it is very misleading and technically wrong. its volume and velocity. EGTs are a bi-product.
BOOSTAHOLIC ;-)
boxy
Re: my 10 pennies worth
Post by boxy »
slaphead wrote:Assuming standard everything, you want an earlier spool up, OK?
One thing I found when I had my standard tubbies up rated to steel internals and roller bearings was a very noticeable increase to boost in the lower rev range - the roller bearings were responsible for this - I would also replace the boost controller as the greddy can be adjusted to help in this area as well as getting rid of the big power step at 4k
Don't know if this helps but it might be a cheaper option and it is well tried and tested.
Mark
I think the change of the internals here, allows for a better friction co-efficient allowing the turbine and compressor to accelerate with less load, therefore increased velocity of the gas and more power with less lag. Can you tell I work on aircraft engines?
Bladerider
boxy wrote:Can you tell I work on aircraft engines?
Yep,
Cos your car looks like its got wings !!!
:D :D :D :D
boxy
Post by boxy »
ha ha nice one, supose I walked on to that one.
hybrid dreams
Mark
sounds like a whole bunch of fancy words...to explain something simple.
take it u are in the RAF? are u a crewchief or u actually an engine tech?
BOOSTAHOLIC ;-)
boxy
Post by boxy »
sorry I have my moments, yes I work on Tornado engines as a Junior Technician in the RAF.
