my xmas pressie from the cats arrived ...
sorry I thought that was the whole point, less weight on the Crank pulley equals less inertia to overcome. I supose changing the auxillary pulleys will have mimimised a certain amount of inertia. Just thought you would have gone full hog and done the crank at the same time. Hence why I was asking about the timing. I understand though that ripping half teh engine appart is quite daunting.
This may or may not help...
We've had lots of questions about crank pulleys lately, so here's all we know.
First, the crank pulley is the main pulley on the end of the crank (duh) that drives the accessories -- alternator, water pump, and air conditioning compressor.
An "underdrive" crank pulley is a pulley with a smaller diameter. The result is that it drives the accessories more slowly, and with greater mechanical leverage. It's like pedaling a bicycle up a hill with the smallest sprocket engaged on the crank. The goal of the underdrive pulley is to reduce drag from the accessories on the motor. Of course, if the accessories are turning more slowly, they will also be that much less effective, but life is all about compromises.
Does an underdrive pulley really add horsepower? The pulley manufacturers say they do, and we've seen tests in magazines that seemed to indicate signficant gains. But you could get the same sort of gains during a drag race WITHOUT an underdrive pulley by removing the belt from your alternator. (The motor can run solely off the battery for a short time.)
The other benefit of aftermarket pulleys is to reduce rotating mass. Here the simple aluminum crank pulley has a big advantage over the heavy stock pulley, but there's a reason it's so much lighter: It's missing the harmonic dampener. The reduction in rotating mass may be worth a couple of horsepower. But removing the dampener seems like a bad idea to us.
The factory crank pulley has a built-in harmonic dampener, in the form of a split design, with a thick rubber pad sandwiched between two steel sheels. The dampener is designed to absorb torsional and vertical vibrations from the crank. MOST underdrive crank pulleys (with the exception of the Buschur Racing model) do not have a harmonic dampener at all.
Torsional vibration is a twisting vibration caused by the pulses of each combustion event. The force of the piston causes the crank to deflect ever so slightly in the direction of the force, and when that force goes away the crank ever-so-slightly springs back. At certain frequencies the crank can resonate, making the vibration much worse. This is where the harmonic dampener comes into play.
Although many DSM owners have removed the harmonic dampener crank pulley without incident, doing so almost certainly increases crank bearing wear, and COULD lead to early failure of the crank or crank bearings. Just how much the life of these parts is shortened is unknown.
We do have one piece of first-hand experience, to offer, though. We know of ONE instance of crank failure on the 4G63 motor. It was a 2.3-liter motor that belong to an employee of ours. The crank cracked in two -- the only time we have ever seen this happen. That block had an undampened crank pulley on it.
On a race motor, increased risk of bearing or crank problems is insignficant next to the risk of, say, detonation in the cylinder that could blow up the motor. So for a race block, we heartily endorse lightweight undampened crank pulleys.
But for a street-driven car, one that you might want to last a couple of hundred thousand miles, we do not recommend using a pulley without a harmonic dampener.
One last note: The rubber in the OEM crank pulley gets old and weak over time, and it's not uncommon on high-mileage motors to see the crank pulley completely come apart. This can be a serious problem if the accessory belts wind their way into the timing belt area. The moral of the story: Inspect your crank pulley the next time you're working on the car, and replace it if it shows any signs of looseness or wobbling.
The whole point was to remove rotating weight and removing 2.5 kgs is what I have done on the crank pulley. This goes on the crank and is a pulleyboxy wrote:sorry I thought that was the whole point, less weight on the Crank pulley equals less inertia to overcome. I supose changing the auxillary pulleys will have mimimised a certain amount of inertia. Just thought you would have gone full hog and done the crank at the same time. Hence why I was asking about the timing. I understand though that ripping half teh engine appart is quite daunting.
Removing the front of the engine isnt a problem nor daunting to me now - I have done i before when I changed the cam belts and tensioner/idler - it is just not worth changing a very small cogged pulley nor even adviseable.
If this is true iam ordering one too
Well every 1kg you save from rotational weight is supposed to be the same as saving 10kgs of wieght from the car. So that should give you an idea. They won't do much on there own but match them to a lightwieght flywheel and you should save a good amount. This will make the car rev more easily.
