Trust me, you could read the signs. They were massive.323ian wrote:But surely it is only ok to drift when there is no one directly behind?
I did half the day in a drift car and only tried to drift if the road was clear behind me and in front in case i messed it up and spun.
There is no way i could read a sign on the back of a car to see what the car planned to do at the next corner.
Big enough for the marshals to be happy.
As I said, the biggest problem was that people were following way too close and if you had been practising that particular corner all day and wanted to drift it as much as you can, you had to wait for 3 miles until you got there again. Then the same would happen, someone else would be following you too close.
Yes, we got a telling off as someone had complained that we were drifting with people behind us. As soon as we put the signs up on the rear screen we didn't have a problem with people following too close into the corners. The marshals were happy and the idea worked - a result I think you'll find.
