What happened to the neg camber at the front?
It looks like they have aligned the wheels but there is an awful lot more to it than that.
Yep it does! Looking forward to seeing the difference tomorrow. I have been unhappy with the car for a while now, and now i can see why from yours and Autotest's reaction to the settings.dynamix wrote:No offense but with those settings it would understeer like a pig from hell
I think that looked about right for mine - unfortunately I cant run any more rear camber until I fit adjustable lower arms and I cant see anyone that maakes them with the yaw sensor mount that I need for the DCCD, so will have to live with it. I may stick with more neg camber up front for the moment.ESL wrote:Looking at the pyrometer readings on mine, 1.5deg neg camber all round looks to be close.
Have you spoken to Zak about Noltec rear top mounts. I meant those rather than OE.dynamix wrote:I was told the camber bolts wouldnt fit and the rear top mounts are non-adjustableGerry H wrote:Rear top mounts not give you a bit too?blacky wrote:Dunc, are RR camber bolts not avialable to allow a wee bit more???
