Project STi Time Attack
I dont know if it suffers the same buy denso 850cc injecotors (used in the fd3s) casue problems when they are enlarged. I have heard of many problems and lost engines. When this is done to injectors it destroys the spray pattern and therefore gives poor atomisation.
Scott
Scott
Thanks for the concern Scott, the injectors are professionally modified and balanced for flow rates and checked for proper atomisation of the fuel. The reason for using modified rather than larger is to keep the injector opening lag the same which can cause very uneven idle when changing to bigger injectors on EJ engines.
This way, we can purely scale the flow rates to reduce the IDC and put the boost back up to a proper level to use the newly available fuel as we know it flows the air now.
Prior to the APS kit it was flowing a max 290 grams/sec air at 1.45 bar, now it is flowing 300 at 1.2 bar and has the capacity to flow 465 grams/sec if the rest of the engine could either take it or provide it and still be within appropriate map cells to ensure correct fuelling. I am expecting it to come out with around 330 grams/sec but will report back once mapping has been done with results of logging.
We will maintain AFR at around 11:1
Some maths for Scott
330 grams/sec equates to 19.8KG/min of Air coming into the engine.
At 11:1 this would equate to 1.81kg/min of fuel
Shell V-Power has a density of 754kg/m^3, or 0.754g/cc.... we have 740cc worth of fuel per injector and there are 4 injectors, so we can move 2960cc/min of fuel, which at 0.754g/cc is 2.232kg.
Assuming 330 grams/sec air coming through the injectors will run at approx 81% IDC
With normal fuel you end up with somewhere between 20 and 22 BHP for every kg/min of air that you move through the engine.
If we run at an AFR of 11:1 this would yield somewhere between 396BHP and 435.6BHP
Dunc... there are sessions you can attend to talk about problems like this. You all sit in a nice big circle and talk about your problems
