Japanese Intermarque Sprint Challenge 2007
We know how well the 070s work in the wet. There was a good demonstration at Debden. Mind you the driver was pretty hot too
Logan, you may get away with it. I had the std suspension and STi rims with RE 040s and they touched one rear wheel arch on compression due to fast cornering,
road undulations or loaded boot, or all three
To overcome it I had the rear arches rolled and needed a 3mm spacer behind the rear wheels, as the tyre just touched the OE strut.
Since then I've had Yoko 0A48s and RE050s with no spacer that didn't touch anywhere. The Toyo 888s are 215 section so no problems there.
The 225 section is a little tight on the classic but the difference with the 040s was the very square section. The others are slightly narrower across the tread and more rounded.
That's what I've found HTH
I'll be looking at 070s once the 888s have expired, which may not be too long at this rate :-D
That was quite a demo. FTD from the roadgoing saloonsGerry H wrote:We know how well the 070s work in the wet. There was a good demonstration at Debden. Mind you the driver was pretty hot too![]()
Like you say, the RE070s seemed to work well in the wet as Duncan has said. Maybe a one tyre fits all? Save mucking around changing them all the time
