If a Bov isn't required, why did they fit them? - have you introduced a problem waiting to happen?.
555 wrx sti
Awesome performance - Going to have to follow suit with mine, well once I've replaced the fmic piping - I need a set with a lip, increasing boost is just going to make them pop off sooner
The case of dump valve or no dump valve seems to come up all the time of the US RX7 forum. Mixed opinions about it damaging the turbo etc etc.
Good power for the spec.........Ben you need to put your hands in your pockets !!!
as a general rule the TD series tend to be quite happy to run with no d/vale but on the VF series i would err on the retain side normally...............
So glad you've posted this - I was ready to follow suit ... VF28 in mine, going to go down the converting the ssqv to recirc route.stockcar wrote:as a general rule the TD series tend to be quite happy to run with no d/vale but on the VF series i would err on the retain side normally...............
Just a little update as ive decided to go into modified as i don't wont to tax and insure the car which puts me out of road going as these have to be present for this class. i can remove the back seat and the carpet so after removing the interior and a tidy up of the floor i had a couple of two pack cans made up and give the floor a freshen up really pleased with the results.
So hopefully ready for the first round at north weald on the 16th march
life rules
