[quote="andycaca"]wire it up to the alternator, problem solved! ]
You would need an inverter as well as I suspect that the leaf blower does not work on 12v.
How about a petrol driven one? - problem solved
Nik
Are some people so thick?
Link to web site:
http://www.r34gtr.piczo.com
Link to web site:
You cant beat a lean afr with stock timing and a dry n20 system... The afr for the percentage power that the n20 made would have to be in the 7.1:1 range with a few degrees less timing. All this in mind it must have been a tiny amount of n20.
Scott
Scott
