More track tyres
Not sure Phil. They may be a newer design I suppose but the 2012 model looked like this
The reason i ask about the weight is i have seen the maxsport ones at autosport last year and they were soooo heavy .
Seems these may be a good alternative.
Likes ? - http://www.facebook.com/lovablemonkeys
Maxsport and Colway's always used to be remoulds mate, so you would be right there/A2ON wrote:The reason i ask about the weight is i have seen the maxsport ones at autosport last year and they were soooo heavy .
Can't see anyway in Hell that these would be any good in standing water but damp or light rain and they should be OK (but then I always thought R888's were ok in those conditions too)TheNissanMan wrote:Stupid question but I take it they're as bad in the wet as they look...
Currently running AD08's which I find bloody awesome wet or dry but always after something stickier if it can get me to the track in the wet
Not Colways or Maxsports. These are new tyres.
You guys are just confusing yourselves. Just wait till i have more info for you ok.
Weighed the 225/45/17 sample at 10kg. Not bad considering that to create a stiff sidewall is bound to add a bit of weight.A2ON wrote:The reason i ask about the weight is i have seen the maxsport ones at autosport last year and they were soooo heavy .
Pretty good given the same size R888 weight 10.882KGSFast Eddy wrote:Weighed the 225/45/17 sample at 10kg. Not bad considering that to create a stiff sidewall is bound to add a bit of weight.
I think these only go up to 225's but as I don't know what the make or model of tyres are, you may want to take that with a pinch of salt Pete
