strange goings on in transit
warboys
Post by warboys »
Does it always start ok? Cheack the engine earth straps for good connections.
always starts ok,
cheers for the links lee i'l check the wires and plug
It does sound like an earthing problem....but have you had it on a scanner yet Trev? It just might be an ecu /uch (or whatever ford refer/call the secondary control unit) fault?
no been on a scanner russ , belive it or not i cant even find the plug , its not where its supposed to be, i had a quick look at work today underneath the earth from starter motor to alt was green and corroded, but i was a bit busy so jst gave it a wiggle :)
Tk wrote:no been on a scanner russ , belive it or not i cant even find the plug , its not where its supposed to be, i had a quick look at work today underneath the earth from starter motor to alt was green and corroded, but i was a bit busy so jst gave it a wiggle :)
I do hope you`ve found the cause then and get it sorted before the weekend, so you can go off to cornwall with a clear head!:party:
I bet you don`t come back with one?:)
off to cornwall this evening in the van fixed or not , probably not fixed but it seems to work alright for the last couple of weeks like it,
have a good one at north weald , im a bit gutted im not there to play
Well Trev, Did the van make it to cornwall and back? Was the hangover worth it?:D
made it there and back 900 miles although i think my brain is still there , it was a great weekend with plenty of rattler cyder and good food in stunning surroundings.
battery light was on all the way home, one thing i did notice on my return is i only have one front side light (could this be the problem) we shall see
You mean you have`nt aready checked all your lighting out for the posible shorting bulb?:toetap05:
i know :o
