Yes - fly by wire throttle.
Mixture of fuel and ignition cut to keep turbo spinning but phased back in gradually when revs drop or traction gained.
Launch Control
Does it use wheel speed sensors too? Just need to figure out how to get the M4 Motec to do it.
I was hoping to knock something up very crudely and simply. Maybe a wheel speed sensor on a rear wheel that sends a signal so that if a rear wheel is stationary the maximum rpm = x. Just need to be able to have that controlled on one of my steering wheel buttons so that if I lock a rear wheel under braking the engine revs aren't cut.
