Chris,chrislandy wrote:I was told by totalseal (whose rings I am using) use propper running in oil then warm it up for 20 miles off boost, limit revs to 4-5k and boost to under 1bar until 300 miles, change the oil and filter, more running in oil and giving it more boost until 500miles, swap the filter and oil for decent full synthetic et voila.
Thing is, it's a balance between what the rings, cams and bearings need - all of which are different
I can only hope that your tuner is experienced with TotalSeal rings and that you're not using them on a powerful turbocharged engine.
My best advice would be to take them out and fit proper rings before you cost yourself an engine like I did !!
I would rather have chocolate piston rings than TotalSeal.
J.
