Once again lady luck kicks me in the nads!(Gently it seems)
Bealo
Post by Bealo »
Hope this turns out to be a cheap fix Rob and that you have some fun with yr car soon....
Well fingers crossed the small split I've found in the hose is the cause, found this morning.
The main stealers wanted 24 hours to get one in, and all I could find was a used one with MOCOM in North Weald.
blacky
Post by blacky »
Nice one Rob, glad its fixed!
Nice easy fix then Rob :D
Lady can be a compassionate mistress after all :grin:
I take it you're aware of the oil change procedure for a Scooby?
Fully synth oil. Pre-fill the new filter before fitting. Disconnect crank sensor and crank the oil pressure up before starting. All good fun :D
@Gerry, yes thanks, I've been warned about some horror stories of people not doing either of those, and then trashing the engine :o
Fingers crossed I won't be on here tomorrow night asking for a new engine! :wink:
Bealo
Post by Bealo »
Bloody Subaru's bloody pain in the arse if you ask me :-D :-D
What happened to just putting the oil in and away you go???????????
yes they are a pain in the ass but they do give a good grin factor :-D
congrats on an easy fix ,
Pain in the arse but they do kick arse eh Trev? :D
they certainly do gerry me ol bean :D
They certainly are different to work on compared with BMWs Stu, I'll give you that!
The E30's, 34's,36's and E46's are all fairly predictable, but the Scoob's given me a few new things to consider! As Gerry says, all good fun :D
