440 injectors + fitting kit for subaru
Need something? ...ask here.
Ian (DaOne)
Post by Ian (DaOne) »
12.29 @ 110.6 santa pod
the scoob is a JDM hoe
ESL
Post by ESL »
Hi Russ, actually a good point has been made, the 380s probably should cope with your current output, but I have no way to measure the IDCs without installing ESL live.
An FPR is a crude way to increase fuelling, but it can be done in a more controlled manner through the ECU.
For general info, all pre 96 Imprezas have 380cc injectors, I'm unsure if phase 1.5 injectors fit directly to phase 1 fuel rails.
OT, are you coming out to play with the gang next Sunday?
Cheers
Andy
Phase 1.5 rails use phase 1 injectors. Phase 2 are smaller diameter so need the fitting kit, which is basically a sleeve and a couople of 'O' rings.
OT? What's that?
