Scooby owners please help !!!!!!!!!!!
stockcar
Post by stockcar »
black wire out of the fuse box???
V3 Sti wrote:Its not a melted piston ad i have not put diesel in it , if i go to the car now it will run fine and after about 30 mins it will play up , i cleaned the maf and it was fixed for a day or 2 then played up again , ive reset the ecu but pullin the black wire out of the fuse box . is there anythin lse i could do ?
Rob .
Never heard of pulling a black wire from the fuse box to reset the ecu. Disconnect the battery overnight. Check for codes, there should be none. Run the car and watch the cel. check error for codes again.
It isn't easy trying to diagnose and fix problems remotely especially with limited info. :roll:
Scooby_RA
Post by Scooby_RA »
stockcar wrote:black wire out of the fuse box???
there is two black and two green wires under the drivers side of the dash, putting these together black to black and green to green gives ecu reset, just the blacks give fault codes using the engine check light
MY95 WRX STi Type RA
They're nothing to do with the fuse box.
Have you actually checked that doing this clears the fault codes from the ecu?
The ecu hangs on to fault codes until it's reset either by the method you said (although not always 100%) or by disconnecting the battery for a few hours.
You need to check that the codes have been cleared first, otherwise you could be looking at old codes and confusing the issue.
V3 Sti
Post by V3 Sti »
Right thanks for the replys people i'll disconnect the bat tonight and push the green plugs together .
Rob .
S14 silvia stuck at 420 hp and ran out of money !
V3 Sti wrote:Right thanks for the replys people i'll disconnect the bat tonight and push the green plugs together .
Rob .
Not the green plugs. The black ones give the error code read out.
Disconnect the battery tonight and leave disconnected.
Re-connect battery tomorrow.
connect the two black connectors.
Switch on ignition and check that there's no error codes.
Switch off ignition and disconnect black connectors.
Start car and go for a run until you see a CEL or the problem shows.
Switch off ignition and connect black connectors.
Switch on ignition and check for error codes.
Come back and tell us what happened and we'll start again :D
ScoobieWRX
Post by ScoobieWRX »
Uncle Gerry knows his onions :D
Got to try and help. We have the same car model :D
V3 Sti
Post by V3 Sti »
Thanks Gerry i'll do that and report back tommorrow night .
Thanks again .
Rob .
V3 Sti
Post by V3 Sti »
Right Gerry done what you said and now ive got no error codes ;) , but the prob is still there ! somethin new happened today the cat light came on , the car does have a standard downpipe fitted still , could my prob be the lambda sensor ?? Its struggling to rev and pluming out black smoke !!
Rob .
