Lol, Its because of the Twin Screw blower. I get almost full boost when ever I floor it. Regardless of rpm. It starts at 14.5 psi and goes to 17psi at the top. Its a lot of fun!
-D
Hello
Thanks again!! o muchas gracias!!
As for the corners, I have never been to a track and I am not keen on speeding around turns on public roads. I know my car handles a lot better than solid rear mustangs. I have a independent rear with a brace on the diff. I also have sport springs, Caster/camber plates, full length subframe connectors and urethane bushings in the garage waiting to be installed. My car came with Bilsteins so I'll keep those. Downfall is that my block is iron so I am a litle bit nose heavy and understeer seems to be the problem at the track. Someone on a mustang board has "steers with throttle" on his avatar, lol. I am really looking forward to a track day though!!!! I am sure I will learn a lot from you guys.
Thanks,
-D
Thanks,
-D
This must be a great drive Mr Sanchez.
MMMMM.........i can rearange your user name and your real name to make someone famous?????
- Safety_James
rayman gtir
