I'm looking to improve spec of Laptop, Who can help?
Bealo
Post by Bealo »
Tony
the official name of my computer is VGN - T2XP/S
So i don't know if this changes which memory i need?????
thanks Tony.
TonyB
Post by TonyB »
That does make a difference. This can only have an extra 512MB = 1GB total.
Memory, that I *think* will do the job - http://www.ebuyer.com/UK/product/45307
Sony no longer list upgrade memory for this model
Fitting instructions - http://support.vaio.eu/tutorials/memory ... =-1&m=1818
So,
a, is ok. Things will take a little longer compared to a faster processor, but if it is not at 100% for long periods of time then you are not overworking it.
b, If your 448MB is with all your normal apps running, and you notice it slow at this - then Memory is not the problem either. A bit of extra memory is no bad idea, especially when you start opening lots of files/pictures as this is when it will creep up.
c, looks fine and dandy
If hardware wise is ok, which it appears to be, then you need to look at software. Are you up to date with:
1, virus software - AVG free is better than most pay for antivirus if not
2, spyware - Windows defender is my choice for Windows XP
3, windows updates - windowsupdate.microsoft.com
If these 3 are ok then it is prob time for a windows reinstall TBH not much point battling any more with it. I assume it appears much slower than when you first got it with fresh windows?
Tony
'05 Subaru WRX 300
R.I.P
'89 ST185 GT4
ONLY 370bhp & 405ft/lb @ fly
12.7s 1/4 @ 109mph in the wet
R.I.P.
Bealo
Post by Bealo »
Thanks once again Tony
1, i have and use AVG free edition
2, I will install windows defender
3, I will log on to windows update and see what it offers me.
Bealo
Post by Bealo »
Tony
One more question, how easy is it and how big can i upgrade my hard drive????
TonyB
Post by TonyB »
The HD's are normally normal fitting on Sony's, but I can not confirm from the tech specs available so you will need someone to look at the physical disk to confrim, so you should be able to fit and 2.5" IDE Notebook disk:
http://www.ebuyer.com/customer/search/i ... owAll=true
How hard these are ti fit??? And you will then need to reinstall windows.
Personally I would just got one of these:
Small enough to fit into your shirt pocket, and just one wire - USB to Laptop. You can then pulg this into ANY machine for easy transport of files.
'05 Subaru WRX 300
R.I.P
'89 ST185 GT4
R.I.P.
