Do you need to have different maps if you use a Low and High boost setting on your boost controller. We have always just had the 1 setting but would like to be able to run a high and low settings.
Or as Alan put's it 'Pablo Boost' and 'Bart Boost'.
Boost Controllers
Re: Boost Controllers
No mate, you map it across the range and upto the max boost you're going to run (with safety cut-offs if this is exceeded)- then you just set up your high and low boost settings with your controller.
Finishing off the Ford
Thanks Danny, thats made me happy
