Fuel surge tank set ups
Where's the best place/price to get a fuel surge tank kit from and does anyone have pics of their set up.
i think id go with a tank and swirl pot in boot if it was me.
so just a simple walbro?, you planning any more power if so how much?
if you still want to go with your tank just use your pump to feed a swirl pot and then have a bosch 044 feeding forward.
remember to use a good filter
walbro isnt as good as a 044,walbro will only just do 500 ,044 safer to 600-650
so as said yours pump you have to feed swirl pot and buy a 044 with filter and use that to feed rail,but also if a cosworth tank is a better design id be changing that too to be sure
I should really be more specific when I tell Alan what we're using....sorry mate:blush5:
Gary the fuel pump that we are running is a Driven2Automotive - DA-27 High Performance Fuel Pump - 255 lt/ph. (Circa 450-500)
I was thinking of using a walbro lift pump and then 2x DA-27/31
OR
could we use our pump as a lift pump and a single bosch 044
Is there any advantage of using 2 pumps as opposed to a single pump?
OR
if you can manage with just a single bosch then id say its the answer,i run to pumps running together but if one fails it can leave engine with less pressure and go lean,
on mine i have protection from motec dash etc so not a problem
ive never heard of pump you using
Cheers Gary:thumbs:. That was the idea with running 2 pumps so if one fails we have protection. This is the pump we are running.
http://www.ebay.co.uk/itm/D2A-255-DA-27 ... 2554498fd4
