The stickers have all now been removed
Spec is
APEXI POWER FC+COMMANDER.
NORRIS DESIGNS INTERCOOLER
GARRET T28 TURBO.
5ZIGEN 3 INCH EXHAUST.
3 INCH NORRIS DESIGNS DE CAT.
FORGE DUMP VALVE.
UPRATED SPORTS RADIATOR/FANS.
BILLION FAN CONTOLLER.
BLITZ DUAL SOLENOID BOOST CONTROLLER.
APEXI AIR FILTER.
SAMCO HOSES.
SARD FUEL PRESSURE REGULATOR.
8MM SILICONE LEADS.
SUMMIT WATER CATCH CAN.
POLISHED POWER STEERING RESERVOIR.
NISMO OIL+WATER CAPS.
POLISHED HEAD.
ENGINE DRESS UP PARTS.
IRIDIUM PLUGS.
SUSPENSION/BRAKES
TEIN TYPE HA RACE COILOVERS.
ADJUSTABLE PILLOW BALL MOUNTS.
CROSS DRILLED/GROOVED DISCS.
UPRATED PADS.
BRAIDED HOSES.
To be added over next week due to clutch slipping a new clutch and lightweight flywheel
The map on the ECU also needs sorting so hoping to get it into Gary at APT as soon as clutch is sorted for him to sort that.
Cheers
Marty
