anyone know where i can find large rubber grommets approx 1.5"
im not using sliders on polycarb windows and need ventilation and planning on drilling some holes with a hole saw, only problem is the car is kept outside and had a plan of pushing rubber grommets in the holes to keep the water out when its not being used
looked through 17 pages of ebay with no joy
Not the ones i really wanted to link too give me a while before you commit as if i can find the ones iam thinking of you will probably go for them
i'v ordered a pair of these as there so cheap and larger than the ones above being 79mm
http://cgi.ebay.co.uk/Aircraft-Cockpit- ... 240%3A1318
worth a punt i thought
