Can everyone post up some picture of content they have as I am looking at how to develop something for the back/under tray for my car.
Cheers
Rear Diffuser / UNder Tray Diffuser
Um where you looking to purchase that fron dunk as i may be slapping one on the evo at some point? They make them for the 7-9 but not the 5-6.
I am looking at Ally at the moment much easier to make and mould to what I want.
Will be looking at a complete under tray the full length of the car, the idea is to have some bonnet scoops upside down in the tray to bring air flow into areas that need it ie.
Diff / Geabox and also for rear brake routing....
Here's a link to the rear diffusers on RX7s mate:
http://www.fd3s.net/diffuser/index.html
It has been a little while since i did any real aerodynamics, but the angle change on that diffuser looks very aggresive. Air may stall/ break up and make the diffuser less effective, so just be careful it is a real diffuser you copy and not just a piece for show. Most race cars based on production bodies run very shallow angles unles there is a huge rear wing very close to the diffuser interacting with it. Most diffusers on sports and supercars are exagurated for looks over real performance. The rule of thumb i was taught is 7 degress constant slope angle is safe, 13 degress is the maximum you may get away with without interacting flows.duncan wrote:here is what mine is going to be based upon:
when I get round to making it
F430 road car:
and race car:
Covette endurance car:
Very easy to make, but dont forget the loading they create (having seen a few diffusers and splitters colapsing or ripping off the brackets!). 100kg at 100mph should be easy enough to create from a subtle diffuser if you are making a flat floor too.
