Code: Select all
A:From Jeffrey M. Mayzurk and also the APS catalog:
More Understeer More Oversteer
(less oversteer) (less understeer)
decrease front tire pressure increase front tire
pressure
raise rear tire pressure lower rear tire pressure
increase front swaybar diameter increase rear swaybar
diameter
decrease rear swaybar diameter decrease front swaybar
diameter
less front camber more front camber
increase rear camber decrease rear camber
increase front shock stiffness increase rear shock
stiffness
decrease rear shock stiffness decrease front shock
stiffness
