TrackDay Beginners Checklist
rolty
Post by rolty »
Tape will be fine
Excellent check list Dunk, can I just add:
No overtaking in corners or the approach to a corner.
If there's a faster car coming up on the straight, move over to the right and use the right indicator to show you're aware of them and allow them to overtake.
If you're on the approach to a corner and there's a faster car approaching, don't panic or swerve out of the way. It's your corner and he/she should follow you through. Once through, indicate and move over to the right.
Hopefully that may prevent the train of cars that can sometimes happen.
puggsy
Post by puggsy »
I've only got the plastic bit if my licence, lost the paper bit a couple of days ago. Will this be ok?
it is fine for Snetterton - but most circuit will want both parts.
Nik
Post by Nik »
If you are using octane booster remember to take extra incase you need to fill up during the event. The fuel pumps at circuits don't normally have V-Power :)
Don't think this will be relevent for the shorter events like trackday virgins etc but always worth thinking about.
There's a Shell garage just a few miles North of the circuit on the A11
Pike
Post by Pike »
If you are in a line of traffic or feel that your being held up back off and give yourself enough space to enjoy your car.
2008: VW1 3rd in Class
2009: VW1 3rd in Class
2011: Ginetta Challenge
It's about you - it's not a race, my main advice is be vigilant, fast movers can come out of nowhere!
Pike
Post by Pike »
Something else that had just popped into my head are tyre pressures. In the dry they can build up quite rapidly and it is a good idea to reset them before you go out for a session.
For the wet its a good idea to run slightly higher pressures evenly across the car.
ESL
Post by ESL »
Don't attempt to follow Dunc unless you want to really batter your car. He queeeeek.
