He's sooooooooo competitive !!!!
He gets beat by Bubble, Dan and Mark anyways !!!
J.
BigPower Dyno Results - Results Posted
- Bladerider
Mr mogle there is something very wrong with your car or map son. you are too lean at peak tq runnning that boost level. if the run started at 2000 rpm there is lots of work to be done !
Is there a smoothing factor on this dyno. IF so is it set the same for all runs ?
Scott
Scott
