Heat management time again
Posted: Fri Jun 01, 2012 5:00 pm
It is time we all thought about rising ambient temperatures and heat soak from hot exhausts, engines etc sapping power so we need to keep heat in some areas and away from other areas. If you need advice, just call me.
I have sourced a great value 600 deg C heat wrap that you can see in the foreground. A nice tight weave unlike some of the cheap crap around. Just
