From tower PC to laptop....
Posted: Thu Nov 09, 2006 10:56 pm
by DASHughes
Hi
I have about 30GB of music on my tower pc, but i want to bring it across to my laptop.
I have a wireless LAN that they are all part of.
How do i do it? :? is it best to set-up a shared folder? Or just run Ethernet from PC to Laptop(if poss? :?)
Im a total novice when it comes to these kind of things...
Any help will be appreciated.
Danny
Posted: Thu Nov 09, 2006 11:06 pm
by andycaca
share the folder your mp3's reside in
open your \\desktop\mp3 share on the laptop
drag and drop
or you could setup an ftp server/client and transfer files that way, which is much quicker
turn on the Guest account on the desktop machine too, if needed. use google for help because im going to bed now
nn
Posted: Fri Nov 10, 2006 7:39 am
by Ben
I have done this recently - If the machines see each other on the net work - which i'm assuming they will, and if you have the lastest G router kit - it is quicker to copy by simply setting up a share on both machines and copying. I found it quicker via wireless than via cable as my wireless is 125 and cable 100.
Posted: Fri Nov 10, 2006 9:58 am
by RX7
You will probably need to shutdown your firewall programs if you cant see the other machine.
I always have to shutdown zonealarm on mine and mcaffe on my dads to transfer.
If you are doing this then make sure you take the Internet connection lead out !!!!!
Posted: Fri Nov 10, 2006 11:45 am
by DASHughes
Ok, thanks guys. I will attempt these later....... figers crossed!
