Plug advice
Posted: Sun Oct 05, 2014 3:49 pm
by Ian200sx
Hi looking for opinions on the colour of my plugs, picked up a small misfire today and thought I'd check the plugs
Looking for someone more in the know to maybe help
Cheers
Re: Plug advice
Posted: Sun Oct 05, 2014 7:04 pm
by MrBrooks
A good spark plug will have no build ups or deposits on it and no worn or damaged spots. Look at the colouration of the ground strap to see if the heat range is accurate. Any colour change near the end of the strap indicates that the heat range is too cool, that the heat is being absorbed too quickly to provide a good burn. Colour change that occurs too close to where the strap connects to the base reveals a range that is too hot. The colour transition should occur half way down the ground plug. One of the threads on the plug might also show some discolouration.
Re: Plug advice
Posted: Mon Oct 06, 2014 3:30 pm
by Daniel
Here you go mate, knock yourself out. :)
Re: Plug advice
Posted: Tue Oct 07, 2014 10:38 am
by Ian200sx
I've already had a Google and read about reading a plug I was hoping for someone in the know really. I'll get it booked in for a r/r to have checked.
Cheers
