Stuart wrote:This doesn't look right to me. For starters, I always thought that the torque curve and power curve were supposed to cross @ 5250rpm..........
Only if the power and torque axis are to the same scale (and using units of bhp and lb ft).
Only had a quick look, but if you read up from approx 5252rpm along the bottom scale and check where it meets the power and torque curves, it seems about right- 150 bhp/150 lbft.
