So where to go from here?
The 'Z' wasn't driveable, and there was still a lot of work to get cracking on with.
However another trip to a dirty, stinking shit hole loomed and so the 'Z' was put on the back burner yet again............
fast forward to the present.
The whole thought process behind the original 'Z' build was to turn it into the car that I wanted from the off.
The problem was, there are so many Z32's out there that all follow a similar theme and I didn't want to just go with the flow.
The VG30DETT has so much untapped potential that I decided to focus on the car's abilities as a whole.
Weight was the first priority
So everything that was excess to requirement was stripped off and binned!
The complete interior was stripped out including all sound deadening.
The stock dash was removed, along with all air con/heating components and replaced with a custom carbon fibre half dash:
Ltd Edition OZ RACING 'PERSONAL' steering wheel and Carbon Fibre half dash with military spec aluminium mesh = very strong but very lightweight
The dash is still a work in progress and will shortly (once a decent secondhand unit is sourced) be fitted with a RACE TECHNOLOGY DASH 2 & DL1
These will both work in conjunction with the Race Technolgy VIDEO 4 system that I have already purchased
Once up and running it'll provide FMV and audio from the 4 onboard cameras as well as a customised information overlay option.
Used in conjunction with the RACE TECHNOLGY DL1 (datalogger) via an AEM ECU interface to the AEM EMS.
It provides real time information from the on board sensors in addition to an information recording facility, for after action review purposes.
This will ensure that I know exactly what is happening/what has happened with the car and myself during and after every track session.
A 6 point Auto Power FIA approved roll cage was imported from the US (test fitted and then primered + painted to protect from surface rust)
A lot of the previously upgraded KSPORT parts etc (below) were removed and sold
The complete suspension and handling setup (including HICAS, which was removed completely) was replaced with brand new parts from TEIN, STILLEN, SPL, CZP, WHITELINE and DRIFTWORKS
Including DW adjustable rear lower arms, DW adjustable traction arms, DW adjustable rear upper camber arms, DW HICAS replacement kit, CZP rear droplinks, STILLEN rear anti roll bar, TEIN Type Flex coilovers + EDFC
and TEIN Type Flex coilovers + EDFC, DW adjustable front lower arms, DW tension rods, DW adjustable front upper camber arms, WHITELINE front droplinks, STILLEN front anti roll bar (SPL V5 tie rod ends & TEIN Z33 inner rods are currently on back order with SPL PARTS in the US) but should arrive and be fitted by the end of the month)
