Amazing
Ben and Daniel, both these finds are excellant and the info that you've provided is so helpful I have been wanting to run multiple camera's and to be able to edit it into picture in picture format. At the moment all spare cash and time is going into our new project but once built I am sure that I will talking to you both.
Absolutely .. obviously dependant on the editing software - with cyberlink you can import many different formats of footage, say for example you had 3 different sources of footage, you would import all three into cyberlink.
You then drag the footage onto the time bar and edit as required - when you 'produce' the finished footage it will be combined into the format you have selected as the output.
With the footage I did as a test I simply created a solid background then inserted two picture in picture entries and added each short clip to those. Then 'produced' the finished article in a 720p format - which to be honest looks to be exactly the same quality as the original.
You know what Ben, i can't wait to shoot some Marham footage now we both have these video cameras as well as our normal size ones. Should make for a very interesting cat and mouse video
