Need to get at least 3 to get a good price.... through Mocom Racing
This is a fantastic FMIC and will do a great job at charge cooling with increasing lag too much.
Professionally engineered performance for 350 - 525 horsepower applications
Unlike other systems that require cutting of structural components at the front of the vehicle, APS has designed the D/R Series FMIC with a truly bolt-on replacement unit that not only maintains the structural integrity of the vehicle, but also forms the perfect mount to accommodate the largest FMIC available for a WRX and STI. Even the stock fog lights are retained!
This provides the maximum cooling capacity and engine performance and of course, killer looks. With intercooler core dimensions of 9.375" x 33.5" x 3.25" for a surface area of over 314 square inches and a total intercooler core volume of 1,020 cubic inches.
The APS intercooler core is of internally finned construction and offers significantly enhanced flow and heat exchange performance over the standard intercooler and other front mount intercooler systems, particularly at high charge air mass flow rates. Also, unlike other manufacturers of WRX intercoolers who reduce cost by using deeper cores of small frontal area, the APS D/R Series intercooler is designed with the optimum ratio of intercooler core surface area (over 314 square inches!) to intercooler volume (1,1020 cubic inches). The result is an intercooler system with outstanding flow and cooling performance, particularly at high engine horsepower levels.
Available in Stealth Black or STI Silver
As soon as there is enough interest I will be able to confirm a price but RRP is normally around
