Performance Friction
what is the cost of a PF 330mm x 30/32mm rotor .
Jason
;) What have you bought Fletch? :) Did you get that type R set up from Bealo? :cheers2:
sssshhhhhh don't tell everybody :D going to have a better mockup this weekend:sifone:
Tommy
Post by Tommy »
Type R? 330mm? Does not compute!
its not a jap type R tommy more home grown:biggrinjester:
stockcar
Post by stockcar »
Tk wrote:alyn do you know if performance friction do a pad for the wilwood 4 pot caliper ?
depends on exactly which pad shape for the Wilwwod but pretty sure they do most.........
stockcar
Post by stockcar »
sidewaysfletch wrote:what is the cost of a PF 330mm x 30/32mm rotor .
Jason
as always depends on exact fitment but as an example if it was the popular AP type CP3580-2898 (but these are only 28mm) then they RRP at
blacky
Post by blacky »
Alyn
Can you do a very special Price on a full front and rear set for a 350z? Or any other good recommendations for them? Car is used just on the road.
Thanks :D
stockcar wrote:depends on exactly which pad shape for the Wilwwod but pretty sure they do most.........
there the midilite 4 piston caliper with 2 pins
and run a 285mm disc
stockcar
Post by stockcar »
blacky wrote:Alyn
Thanks :D
carry in stock and the 2pce discs also for the UK spec cars with Gold BREMBO's
