Arriving at Mocom Racing at 8.30 am armed with all the bits and a schedule of what needed doing we set to work (well, I say we, but it was really Zak and Lee ... I watched
The main objectives were:
- fit Milltek Sport decat system
- fit gauges for boost, air charge, oil temp & oil pressure
- fit colder plugs (iridium 7 rather than the 6 standards)
- adjust mapping to suit the exhaust and reflecting the new knowledge of the information from the gauges
To say we encountered problems was a understatement !!
Anyone that knows the procedure to change plugs on a scooby would not be suprised to see half of the engine bay contents on the workshop floor and an hour later a spark plug appears. To our great suprise, the plug length on these is different to all other subaru 2.0 and indeed Zak's own 2.5 block. The plugs in mine are about 1 cm longer and the hunt for stock of these ensued. An hour later and nowhere had stock of the plugs so re-assembling took place.... gutting. Without these plugs, the full mapping couldnt take place
I wont go into all the other details but suffice to say that Zak and Lee worked well and eventually everything was back together and it was time to fire her up.... lovely sounds pulsed from the Milltek system - not too loud but definitely purposeful :evil: If anyone saw the Type 25 on 5th Gear, this is essentially the same system give or take some ceramic coating on the downpipe on theirs (mine is heat wrapped) and theirs has a sports cat.
The final kick in the goolies was a laptop that refused to then connect to my ECU in order to commence some basic adjustments to the maps to account for the free flowing system - you have got to love Bill Gates and his emporium :x . About another hour was taken trying to get to the root cause of this until we eventually settled on going out for a drive to check for knock and measuring with a wide band Innovate system. We would have to leave the mapping for another day where we could do the plugs aswell for good luck.
Early on in this, it was blatantly clear that the turbo would be overboosting if I were to try and drive normally - we recorded 1.44 bar on a half throttle 3rd gear pull to 4000
I would like to thank Zak for the work done - totally professional, great installations and as ever, great advice.
Heres to Friday when I can finally put my foot down
