I need a pair of dead - no longer working - iffy - suspect AFM's .. effectively to act as tubes for connecting the Induction for an RB26 - so if anyone has a duff set lying around can I buy them - I need these by the 15th of August.
Cheers
A set of dead AFM's for RB26
Ben,
If you are losing your AFM's to go D Jetro all you need is some tubing/adapers. I am sure i can sort this from my vast range of alloy/silicone tube stocks.
Pop see me.
Pop see me.
Cool - it's actually Bryan's car that would need the kit so I can remove the afm's from his .. it was just to do a quick and dirty swap out so I can drive on mine own until his are fitted and the car is mapped.
He has a single turbo - but dual intake pipes running into it .. so it's kinda of original induction into the single ...
Well i have pipework to act as replacement for the AFM's.
As for the twin to single pipe, these are a specialist part done by the likes of HKS etc
