Laptop urgently wanted
Posted: Sat Jun 07, 2008 7:59 am
by duncan
Cheap as you can... (and I mean really cheap
Spec not important so long as it works and has 2 usb connections.
Just need for logging/mapping - I will load a fresh version of XP on it.
Posted: Sat Jun 07, 2008 8:45 am
by Gareth_evo5
I've got an old Gateway LT, battery is knackered so needs to be run from a 240V inverter
It's available today, if you need it that urgently, give me a ring on my mobile (07896231016), I'm in Littleport so not that far away.
Haven't powered it up in ages,
G.
Posted: Sat Jun 07, 2008 8:48 am
by duncan
Cool - how much do you want for it Gareth ?
Posted: Sat Jun 07, 2008 8:58 am
by Gareth_evo5
Try it, make sure it fits your needs and make me an offer, just remembered it does have a problem with the touch pad, so you have to use a mouse with it, I did buy a second pad off ebay and that didn't work, so suspect the problem to be on the MB, so I won't be wanting much for it.
This might cause you a problem if you need 2 USB ports, it has 2, but 1 will be needed for the mouse, unless you use a usb hub.
G.
Posted: Sat Jun 07, 2008 9:02 am
by duncan
I am not sure I will be able to use a mouse with it Gareth.
I will try and find an alternative. Thanks.
Posted: Sat Jun 07, 2008 9:18 am
by Gareth_evo5
No problem, it's there if you want it, and to be honest I don't want anything for it, it's of no use to me anymore and I'd rather see someone use it that sat on my shelf.
I did use to play with the VAG_COM on my old VW Bora, and it was a bit of a handful in the car (it's also got a big screen).
G.
Posted: Sat Jun 07, 2008 9:40 am
by drifter
I've got my old laptop, it's a Patriot I got from PC World. Touch pad works fine, quite small and has 4 usb ports. I did have someone ask about it, but if you want it Dunk. Say
Posted: Sun Jun 08, 2008 7:43 am
by duncan
[quote="drifter"]I've got my old laptop, it's a Patriot I got from PC World. Touch pad works fine, quite small and has 4 usb ports. I did have someone ask about it, but if you want it Dunk. Say
