Has anyone got or knows the where abouts of some 440 injectors + fitting kit for my 94 wrx wagon?
My standard 380`s are running out of puff at the top end!
Anyone know where else to look :?:
Cheers
russ.
Thanks Jason!sidewaysfletch wrote:i think ( daone ) had some 550 ones he was getting rid of![]()
jason
Thanks folks!ScoobieWRX wrote:Those 380cc injectors should be good for c.300bhp at the flywheel so i agree with Duncan about installing a better fuel pump, and i would probably fit a power valve / adjustable pressure regulator as well.
If you fit 440's i would definately fit a better pump and fuel pressure regulator.
