Wanted: Clutch release bearing..........
Posted: Tue Apr 15, 2008 5:58 pm
by ScoobieWRX
I need a thrust bearing for an MY02 WRX with 5spd MT.
In fact the ring that clips over the front of the clutch bearing would do for me as i've accidently bent mine removing the engine. New would be good or a good used one will do me. Let me know how much you want and if you can post it.
Cheers,
Francis
Posted: Tue Apr 15, 2008 6:03 pm
by Gerry H
I don't think the clip comes with the bearing.
Why not try the local dealer? You may be surprised.
Posted: Tue Apr 15, 2008 6:17 pm
by ScoobieWRX
I called my local stealership and they wanted effing ridiculous amounts of money for the release bearing (
Posted: Tue Apr 15, 2008 6:23 pm
by Gerry H
Did you forget to remove the release lever pivot pin then?
Posted: Tue Apr 15, 2008 7:02 pm
by stockcar
can supply a new bearing for half that, BUT the clip your talking about is part of the cover as gerry said.............
wil be able to salvage one and post it for you..........
alyn
0191-4103770
Posted: Tue Apr 15, 2008 7:58 pm
by Gerry H
Well done Alyn! Sorted :D
