I need a thrust bearing for an MY02 WRX with 5spd MT.
In fact the ring that clips over the front of the clutch bearing would do for me as i've accidently bent mine removing the engine. New would be good or a good used one will do me. Let me know how much you want and if you can post it.
Cheers,
Francis
Wanted: Clutch release bearing..........
can supply a new bearing for half that, BUT the clip your talking about is part of the cover as gerry said.............
wil be able to salvage one and post it for you..........
alyn
0191-4103770
alyn
0191-4103770
