injectors for impreza
Need something? ...ask here.
Ian (DaOne)
Post by Ian (DaOne) »
I am after something bigger than 550cc, for a version 6 classic, phose 2 i think. mayb around 650cc.
the 550cc i have at the mo are allmost at 100% on the apexi commander, with 3.5bar fuel pressure
12.29 @ 110.6 santa pod
the scoob is a JDM hoe
Go for 740's - might as well get some proper ones :)
ScoobieWRX
Post by ScoobieWRX »
Why not increase fuel pressure to 4 or 4.5bar whilst you're looking out for some new injectors. That would make sure that even at 100% duty they wouldn't be leaning out on you so long as you leave the tune as is.
Walbro dont like working at over 5.3 bar pressure.
If ian is running 1.6 bar then 3.7 bar is the max I would go to.
ScoobieWRX
Didn't he say he was running at 3.5bar?? Surely if he increases that by .5bar to 4bar it's well within the capabilities of the walbro??
Or did i read it wrong?? :)
What boost are you running Ian?
Ian (DaOne)
it is ment to be peeking 1.5 bar boost, and the fpr is at 3.5 bar
Ian (DaOne)
as i got my cat booked in for another map tweek, since my last one a couple of weeks ago, i was wondering if there was anything worth doing.
on the rr at clives, he said the fueling was spot on, but it stills comes up 100% on the injectors on the apexi connamder
Ian (DaOne)
bttt
