Wanted: R32 GT-R Fan belt
Need something? ...ask here.
V8_EATR
Post by V8_EATR »
As above. Needed ASAP please!! My engine sounds like a bat cave on start up! :x
323ian
Post by 323ian »
Get one from Nissan, you have one in thetford mate.
JP_Tuner
Post by JP_Tuner »
I wish I would've known that before I ordered my parts from a 3rd party.
You can order all parts for a GTR from Nissan, it's just sometimes it's expensive !! ..
V8_EATR
Post by V8_EATR »
Thanks, found the hidden Nissan dealership on my way home today. I'll have to pop in and see if they can help.
323ian
Post by 323ian »
If you are getting a fan belt then get the other two at the same time and change the lot as you will have to remove them anyway.
V8_EATR
Post by V8_EATR »
323ian wrote:If you are getting a fan belt then get the other two at the same time and change the lot as you will have to remove them anyway.
Was reading Mirage's thread and decided to go with the Power Enterprise V-Belts. They say they're super strong and they will look good in the engine bay as well! :-D
Found two out of three that I need, fan belt and power steering, now just need the air con belt.
BNR32 89/&#65374]AIR COND - 4PK910 $38[/b]
