wideband lambda kit and gauge
Need something? ...ask here.
jamie3
Post by jamie3 »
Hi im looking for a wideband lambda kit and gauge new or used (good condition)
Cheers
drifter
Post by drifter »
Send a PM to Gary@APT, they have these. I think they are the VEMS units which can also show EGT if you buy the extra sensor :)
maff
Post by maff »
Ive got one of the VEMS ones, top bit of kit, dataloging to pc graphing and all sorts of cleverness.
jamie3
Post by jamie3 »
cheers guys will give him a ring
Christian and Beccy
Post by Christian and Beccy »
Kit description:
VEMS Wideband consists of:
AFR Gauge in a standard 52mm fitment.
Bosch LSU-4 Lamba sensor.
Complete wiring loom with fused power cable, sensor and multifunction cable.
Gauge mounting hardware.
Optionally: Exhaust Gas Temperature sensor with temperature compensated cable.
Features:
Wideband Oxygen sensor control and display.
Exhaust Gas Temperature sensor display.
Narrow Band sensor output to provide your ECU with the standard lambda feed back it needs for its closed-loop operation.
RPM input to provide context for datalogging.
Boost sesnsor input for datalogging and
5A solenoid driver, to control Boost or N2O solenoid.
Serial (RS232) connection providing datalogging to PC and Field upgradeable software.
VEMS Wideband O2/EGT Gauge complete with Wideband sensor.
Does anyone know if this will input directly into Ecutek Delta Dash for logging purposes ?
maff
Post by maff »
its a serial comms device,
you send it a letter "a" on the serial port and it sends back a string of data with the current info.
Dont know if the Ecutek can cope with that though.
hmm - it might need to go through a translator - will look into it
TonyB
Post by TonyB »
it also has a 0-5v output, IIRC, that can be used on the majority of ecu's ;-)
Just check if your dash has an aux 0-5v input.
'05 Subaru WRX 300
R.I.P
'89 ST185 GT4
ONLY 370bhp & 405ft/lb @ fly
12.7s 1/4 @ 109mph in the wet
R.I.P.
PhatBob
Post by PhatBob »
There is a configurable analog output that will either emulate a narrow band sensor, or can be scaled to give a variety of voltage outputs based on the Lambda reading. If you've got the details for the datalogger I will be able to give the right settings.
Rob
