Hi,
Just had my engine rebuilt by RK and need a power fc that is supported by datalogit to get them to set it up properly. Plus engine has been out so many times for bad rebuilds by others the loom has a fault on the O2 control and the Power FC bypasses this and does it from the map so cures this problem too.
Thanks
GTR/33 power fc
GTR/33 power fc
Do you not want an R32 model or are they the same one?
Stuart,
Thanks for spotting my deliberate mistake!
Should have typed R32/33 but they are the same anyway lol
Ok Ben,
Discount for 10+ order ok lol
Re: GTR/33 power fc
Pretty much all the power fc models for the 32/33 are supported by datalogit - it just depends on what software your tuner has loaded on his tuning kit - as a rule of thumb - if it is an R32/33 model fc with a commander then it should be ok - if it is for the RB26 then some UK tuners dont cover that version with the datalogit software version they haveFast Eddy wrote:Hi,
Thanks
If that helps at all?
~Mark
