A hand bleeding the brakes :)
Need something? ...ask here.
I have the location in my sat nav. What time are you thinking of?
If you know the size of the grub screws and need some, I may be able to find some.
But.... it'll cost ya! :D
I reckon 10/10.30am would be spot on but you can meet me anytime you like Gerry. No idea about the grubscrews. They are supposed to be 1.5mm if they are still in there. I believe they were adjusted with a screw driver and hammer last time around.
get a pressure bleeder, one of the better purchases i have ,can do mine on my own :D
stuart wrote:I reckon 10/10.30am would be spot on but you can meet me anytime you like Gerry. No idea about the grubscrews. They are supposed to be 1.5mm if they are still in there. I believe they were adjusted with a screw driver and hammer last time around.
1.5 mm? I take it that's the key size?
What's a pressure bleeder Jase, got a link? And I'll fetch your wheels with me.
i bought and used a pressure bleeder and ended up with a driveway covered in brake fluid :)
Gerry H wrote: What's a pressure bleeder Jase, got a link? And I'll fetch your wheels with me.
connects to the tyre and then the fluid reservoir pressurises the system so you can crack off the bleed nipples without having to pump the pedal iirc it was the only way i could get my clutch back after removing the slave cylinder
http://www.halfords.com/webapp/wcs/stor ... yId_165469
A pressure bleeder is brilliant, uses air out of a spare tyre, Heres your link http://www.google.co.uk/products?hl=en& ... CBoQrQQwAA
Beat me to it jase!
trev i don't think you are supposed to put 50psi through them lol:D
live and learn ;)
no the one i bought with different size lids for resevoir did'nt fit so made one i'l leave the rest to your imagination :D
shall we all decend on the workshop for bacon butties all round and a bit of banter before the meet? :D
oh, and sort the brakes too. nearly forgot :rolleyes:
