W I D E B A N D..........
That quick? Just eyeballing the gauge mine looks fine after 3 months. When I recalibrate it I'd like to be able to measure the difference. Would you just compare before and after readings for hot idle?duncan wrote:They also need recalibrating every 6 weeks or so as they gradually go out of tune.
Am told that letting it heat up before starting the engine will lengthen the life of the sensor, but it's a little inconvenient.
Andy
At the moment is is running closed loop off the rear O2 sensor only as the front O2 was eaten by a previous turbo and I didnt want to put a new sensor pre-turbo. The innovate will be driving it soon though as soon as I get my finger out and plug it in.ScoobieWRX wrote:Duncan are you using perm install OEM O2 Sensors with the solaris or wideband only now.
