Nissan Z32 MAF Sensor
Posted: Mon Oct 12, 2009 6:48 pm
Having had a bit of a spend up on the Zed this year i'm finally getting round to selling a few of the bits I no longer need.
First up is the MAF sensor, i know a lot of the Skyline guys like these but of course also if the MAF is playing up on your Z32 - if anyone else on BP has a Z32 of course, I feel a bit lonely
Working perfectly when it came off the car in August. Only negative is that the unit is slightly cracked around the bolt flange (should be able to see in pics if I can attach them) but this never affected the way it worked on my car and it flowed OK up to 524bhp on the rollers.
It's pictured attached to Y shaped air filter pipe and 2 mushroom filters which I'm going to post seperately. If you have a Zed then I'll leave these on for an extra
